column 1&2
Posted: Wed Aug 23, 2006 7:34 pm
by gSIr
Hey what do you guys do for tuning in column one and two. I am getting really weird reading of negative 20 to negative 70 in column two, and negative 100 to negative 800 in column one, what do you guys do about this. Thanks for your help.
Posted: Wed Aug 23, 2006 9:59 pm
by smracing
What do you mean "negative"?
Posted: Wed Aug 23, 2006 10:56 pm
by deafy
that can't be good... do you idle in columns 3 and 4?
Posted: Thu Aug 24, 2006 3:02 am
by kaj
are you tuning with by using target a/f?? even if so, i can't imagine it being THAT far off.
more info would help. i don't think any of us know what you are talking about :(
Posted: Thu Aug 24, 2006 10:52 pm
by gSIr
I'm sorry for not being more specific. I idle in column 2 and three. I use a wideband for my tuning. What I mean is that in the delta lambda menu for the fuel maps, the window that shows how many parts of fuel you are away from the target. This is the window where I am getting my huge negative values in column 1 and 2. Just to be more clear, when the delta lambda hits zero, you have reached the desired lambda that you are trying to achieve. For idle I would imagine 14.7 afr is the target, but for some reason I'm leaning out a little at idle and getting the huge negative values, like I have way too much fuel. Just wondering if anyone else has this problem, someone told me to ignore column one and two because of this but I'd rather tune it properly.
Posted: Thu Aug 24, 2006 10:55 pm
by kaj
gSIr wrote:I'm sorry for not being more specific. I idle in column 2 and three. I use a wideband for my tuning. What I mean is that in the delta lambda menu for the fuel maps, the window that shows how many parts of fuel you are away from the target. This is the window where I am getting my huge negative values in column 1 and 2. Just to be more clear, when the delta lambda hits zero, you have reached the desired lambda that you are trying to achieve. For idle I would imagine 14.7 afr is the target, but for some reason I'm leaning out a little at idle and getting the huge negative values, like I have way too much fuel. Just wondering if anyone else has this problem, someone told me to ignore column one and two because of this but I'd rather tune it properly.
my car idles in one and two.. i dunno.
anyway, first: are your target A/F ratios set right? i.e. if they are set at 1000:1 then of course it would be off.
posting your config file would help, also.
Posted: Fri Aug 25, 2006 1:40 am
by gSIr
they are set to 14.7 to 1 all the way across to column 7, i don't see why i would be getting numbers like that far off, is there a way i can record it and show it to everyone
Posted: Fri Aug 25, 2006 1:44 am
by gSIr
This is a small datalog file i have, see what i can do to fix it, I still have a lot of work to do with this map
Posted: Fri Aug 25, 2006 1:50 am
by gSIr
oh yeah and heres my map, this might help. lol
Posted: Fri Aug 25, 2006 9:45 am
You can ignore the unusual spikes. As long as you view the 2d graphs ad they are relatively smooth and your A/F for the most part is smooth, then you dont' need to make any changes. You must remember that when you let off, there is a split second where the wideband will read rich before showign the fuel injectors shut off.
Posted: Fri Aug 25, 2006 10:13 am
by gSIr
oh ok, so when the injectors are shut off the smanager doesn't log that, it makes sense of why it would read so rich, is there anything i can do to solve this?
Posted: Fri Aug 25, 2006 11:23 am
The problem is that your lambda sensor is showing full rich upon overrun, whereas it should show full lean. Look at around 1:10 in your datalog - the injectors are off, but the lambda is cycling back and forward between full rich and full lean. This is a lambda sensor issue.
Posted: Fri Aug 25, 2006 4:05 pm
by gSIr
when the lamba meter sees a really lean condition, it switches to a percentage of oxygen and that switch throws off column one and two, thanks everyone for your help
Posted: Fri Aug 25, 2006 4:25 pm
In Settings, Sensor Overlay, Sensor Overlay 1 (Lambda), try setting the minimum overlay value to 11 and the maximum overlay value to 19. This should filter out some of the rich/lean cycles. You could also set the mimum TPS to 5% which should do the same thing.
