suggestion: memory for data adjustment?
Posted: Wed Aug 23, 2006 3:37 pm
by kaj
is there anyway to make an adjustment to the program so that when i make an adjustment to a set of cells it will stay highlighted?
after data logging for a longer period of time, i'll start making adjustments. as i work down the log, i come across cells that i THINK i've adjusted already.
i've resorted to writing down the rpm/vacuum/boost cells i've made adjustments in to be sure i don't mess with them again, later in the log.
or.. is there a way to do this already?
Posted: Thu Aug 24, 2006 9:12 am
There is no way to do this. You will need to just keep track of your changes and either note them in the notes, or in the file name you save the file with.
Posted: Thu Aug 24, 2006 3:10 pm
by kaj
i figured. no prob. thanks!
sure would be cool, though!
