Does my temp correction really need to be -40 deg
Posted: Mon Aug 21, 2006 5:34 pm
Can I raise the lower columns above -33 degrees? The software won't accept anything higher than -1 in the last two columns. I live in Alabama, there is no way short of some ecological disaster that I will ever have to start my car when it is -40 degrees out side.
How does the software recognize the accelerator pump function? I assume it is based on a rate of voltage change. Is there anyway to modify this algorithim?
