s300 boost control dyno chart using Greddy profec solenoid
airshifter
Post by airshifter »
couple of short pulls to get duty cycles for gear dependent and I full pull
Thank you. What duty cycles are shown?
airshifter
solenoid type- Normally closed
50% = 15
60% = 18
70% = 21
75% = 25.5
78% = 28
80% = 31
87% = 34 (full pull duty cycle)
this car has twin tial 44mm gates and made 13psi when duty cycle was 40% or less, and boost was holding within .5 psi for the pulls untill we got above 30 psi(we ran out of turbo)
Silverbeast
Post by Silverbeast »
Running similar tests with either the AEM or Apex-i solenoids this weekend.
airshifter
I will be doing an AEM solenoid here in a couple of days.
All of my AEM EMS buddies usually don't like the GM solenoid because it is unstable, but I still want to try 1 to see if it works better with the s300 than it does with EMS
Jdogg
Post by Jdogg »
The gm soleniod works fine, its just that if something goes wrong you get infinity boost..
CivicVTi
Post by CivicVTi »
Well, I guess boost cut function saves you from this or doesn't it?
turbo-2nr
Post by turbo-2nr »
airshifter wrote:solenoid type- Normally closed
50% = 15
60% = 18
70% = 21
75% = 25.5
78% = 28
80% = 31
what freq did you run the profec spec2 solenoid at
boostedcivicsir
Post by boostedcivicsir »
judging by the age of the post, 2006, i dont think the frequency option was in that version. i may be wrong though.
