Getting confused after looking at all the schematics for my 1998 Civic DX while comparing to the B18C1 OBD1 schematics.
I am using a 1998 Civic EVAP solenoid. I have a 1997 B18C (JDM GSR) converted to OBD1, running the S300 in a P72 ecu.
The problem is that my car idles in columns 3 and 4, as well as not fast idling at a cold start. So I started going down the list to figure out what could be wrong. I finally found that I had the vacuum lines for the EVAP solenoid backwards. This occurred because I was referencing the 2000 Civic Si solenoid illustration, which is basically a mirror image of the 1998 Civic DX solenoid in the Helms manual. I have not had a chance to check if this got the car to idle in column 1and 2, but it still doesn?t seem to fast idle on a cold start. This lead to another question?
Is my EVAP solenoid wired correctly for the P72 OBD1 ecu? I have a black/yellow wire and a red/yellow wire on the EVAP solenoid connector. According to the Helms the red/yellow should run to the ecu (A20 for an OBD1 P72). But I am not sure if the black/yellow should be a ground or a power source. Currently the black/yellow grounds somewhere when I checked for continuity. Though I haven?t had time to confirm which wire actually goes to the ecu.
Anyone know how this should be wired?
Thanks for any help!
EVAP wiring for ?98 D16Y7 swapped to ?97 B18C with s300
'98 Civic Hatch | B18C | 85mm 12:1 pistons | Ported head | Skunk2 Stage 2 cams
