98 Prelude SH with s300j
Posted: Mon Aug 07, 2006 5:30 pm
by sr73087
I just installed my ecu im having a few problems. I installed a obd1 jdm p72 ecu with hondata s300j. In anyother post i described the one problem but I also have another one. I am also getting an ATTS light and also a check engine light. Under the kickplate where the ecu sits on the SH prelude there are two ecus. The one is the regualr ecu and the other i am assuming is for ATTS. Since ATTS is disabled now should I remove the other ecu completely? Im guessing that by having that plugged in is the reason im getting CELs.
Posted: Tue Aug 08, 2006 9:11 am
Have you tried datalogging and reading the codes? You should remove the ATTS computer.
