Tire size compensation?
Posted: Mon Aug 07, 2006 12:06 pm
by GTMcoupe
Hi team
Got myself a B18C installed in a Kitcar over here in the UK and running hondata obviously, now i have altered the gear ratios to suit my gearbox im using [custom mix of honda ratios] however seeing im running smaller diameter tires than a honda my ECU is reading a higher speed than im actually doing is there anyway i can compensate for this, struggling to find a option for it, still learning the system taking it slowly and easy with my changes
cheers
WEST
Posted: Mon Aug 07, 2006 2:16 pm
There is no compensation specifically for tires size, but you can change the final drive setting which may help
Posted: Tue Aug 08, 2006 10:11 am
by GTMcoupe
see i had thought this too, but when i thought about it, the VSS is direrct off the diff so after the final drive, unless of cause the speed is calculated from engine speed and gear ratios, but i thought it would had been a direct reading from the Vss otherwise why would you use a seperate sensor, ill give the final drive alterations a go in the next couple of days and report back if it works as was going to try this but thought id ask incase i had missed another available option, its not a necessity that the speed is correct but it would be nice for the datalogs of drag runs etc.
WEST
ive had a play
Posted: Tue Aug 15, 2006 7:47 am
by GTMcoupe
Right finally got to have a play today,
from a previous test i was finding that the S300 was giving me a speed 11% faster than what i was actually doing [before you ask i have a very acurate programable speedo fitted to my car]
as suggested by spunkster i adjusted the final drive value to see if this would effect the speed reading.
after a quick blast today with a altered value for final drive with a datalog, and a recall of max speed from my speedo still 11% out,
not a major problem just would had been usefull to get the ecu to agree with actuall speed for datalogged info when racing. prehaps a future little tweak/update.
cheers
WEST
Posted: Tue Aug 15, 2006 8:22 am
The gear ratio and final drive values are use for gear calculation, but have no effect on the ECU speed calculation.
