PLX and capacitor
Zoomie
PLX and capacitor
Post by Zoomie »
I've got a PLX M300 ready for install now and I'm wondering if the included caps are necessary for this application (w/ S300j)? I've searched the forums and not seen any mention of this...
There is no need to install anything extra beyond what is in the instructions on our website.
turbosi92
Post by turbosi92 »
Spunkster wrote:There is no need to install anything extra beyond what is in the instructions on our website.
What have you found as the best ground?
From your directions...
Black Ground - Attach to solid chassis ground
Anything on the chassis that is substantial
Zoomie
Post by Zoomie »
Thanks, Spunkster
Zoomie
Post by Zoomie »
Okay, I'm confused again...
In the tech support section under wiring there are two entries for the PLX Wideband: "PLX Wideband" and "PLX Wideband Wiring". The former says to install the capacitors while the later has no mention of the capacitors. So which one is it?
Also, I've noticed in SManager, under Parameters -> Closed Loop -> Options, that there is a check box to "Disable O2 Heater". Does this mean that you could select this and not have to wire in the resistor when using the PLX? (Does this just ignore the error or does it actually turn off the heater circuit?)
(As a side note: in the former entry, listed above, for the O2 resistor it says 20 Ohm 10 Watt, while the later says 1K Ohm. Again, why the inconsistency?)
Appreciate your help with this; thanks.
You do not need the capacitors
Zoomie
Post by Zoomie »
Thanks for the response Spunkster. What about the second para, though?...
Zoomie wrote: Also, I've noticed in SManager, under Parameters -> Closed Loop -> Options, that there is a check box to "Disable O2 Heater". Does this mean that you could select this and not have to wire in the resistor when using the PLX? (Does this just ignore the error or does it actually turn off the heater circuit?)
You can disable the o2 heater, but it's still a good idea to put the resistor across the heater wires.
THe information on the site has been updated....whe incorrect information had been directly copied form the plx website a while back.
Zoomie
Post by Zoomie »
Thanks again!
