Changing from 93-92 octane
hey everyone, here is something that I was contemplating today. My setup is currently tuned on 93 Octane (Crower cams, Comptech RH, PRC IM, Hondata IMG, Toda exhaust) the area that I moved to has only 92 octane. Would I have to re-dyno tune for 92 octane with cam angles or would it just be a simple AF and ignition fix?
You are nothing more...
Re: Changing from 93-92 octane
You're cam angles and a/f shouldn't change. I believe you were tuned for maximum power on 93, which to me says all you should have to do is retard ignition with some street tuning where it knocks before max power would be reached.EvaUnit01 wrote:hey everyone, here is something that I was contemplating today. My setup is currently tuned on 93 Octane (Crower cams, Comptech RH, PRC IM, Hondata IMG, Toda exhaust) the area that I moved to has only 92 octane. Would I have to re-dyno tune for 92 octane with cam angles or would it just be a simple AF and ignition fix?
PS: your 550's are ready whenever you want them.
