rc 750 sl4 problems
h2nrtl
rc 750 sl4 problems
Post by h2nrtl »
I am having a problem with some rc750 sl4 injectors. They seem to be dumping way more fule into the engine then they should be. Has anyone else had a problem with these?
wdsonny
Post by wdsonny »
If at idle you are getting misfires, then retard ignition on 0 degree cam below 10 degrees. Otherwise, just take away some fuel from the fuel maps and call it a day.
h2nrtl
Post by h2nrtl »
its not just a little to much its flooding
h2nrtl
Post by h2nrtl »
ok after being up until 2am we found the problem. The customer brought us the car with the RCs already installed. The work we found under the tape and not good. Fixed now
spdracr70
Post by spdracr70 »
could u let me know what u found as the problem, im having the same situation
thanks
brian
