PLX M300
Posted: Thu Jul 27, 2006 2:20 am
by 94vtirozguy
i am thinking of getting a PLX M300.
However i dont want this in my car permanently (so i can tune other vehichles).
I don't want to hack the cars wiring harness.
What are ways it can be set up as removable as when i tune i will remove the stock O2 sensor and put in wideband and log to hondata correctly.
If so, how ?
Posted: Thu Jul 27, 2006 9:36 am
Posted: Fri Jul 28, 2006 2:08 am
by 94vtirozguy
link does not work for me
Posted: Fri Jul 28, 2006 9:36 am
Try again, that is a working link.
Re: PLX M300
Posted: Sun Jul 30, 2006 11:36 am
by kesnut
94vtirozguy wrote:i am thinking of getting a PLX M300.
if you plan to do other car get the lm-1... it has less wires to play with.
but on the other hand, if you have the $$$ get the plx for your car a leave it there
Posted: Fri Oct 20, 2006 6:10 pm
by 94vtirozguy
I'm using method #2 and using the adaptor off dead o2 sensor.
is there anything that needs to be done to the other 3 wires on the adaptor off o2 sensor. Like the black black wires joined together ?
Also i do not read anywhere in the link above that capacitors need to be used, however the PLX instruction say you need to use them.
Posted: Sun Oct 22, 2006 8:22 am
by 94vtirozguy
also, with the s200 how do you set the voltage offset, between the wideband and what the actual ECU sees.
I have about a 0.3v differential, and on the s300 you can easily set it, not on the s200
Posted: Mon Oct 23, 2006 10:38 am
No capacitors are needed. You will have to alter your wideband lambda conversion table in the settings for the voltage offset.
