K20A2: TODA, HONDATA and Civic Type R
Posted: Wed Mar 19, 2003 1:39 am
Hello,
I'm Luca from Roma, Italy. I'm a new member of this forum but I'm a very "fan" of hondata products.
I have a Honda Civic Type R (EP3 with K20A2, the same engine of RSX Type S).
In Italy we have the benzine with 95/99 octane.
On my car, I have:
Mugen Airbox and TwinLoop + Central Pipe (54/60mm);
Spoon Throttle Body Assembly (70mm);
Jackson Racing Header with oem honda kat (modified).
Now, I have bought the TODA cams (spec.A) and valves springs.
For this, I need a ecu fot these cams. I have seen that Hondata with TODA has realized a special reprogramming of the factory ECU (for RSX).
This special ECU reprogram maximize performance of the camshafts. The ECU program uses special fuel and ignition timing maps, 9000rpm redline, modified VTEC Activation, and modified VVT camshaft timing.
Now, my question for Mr. HONDATA is:
If I haven’t problem to disabled the immobiliser of my car and knowing what EP3 has power steering electric and not controlled by oil pressure with steering pump (how instead that of the Rsx TypeS is), can you reprogram a CTR ECU with the “Toda programs for RSX”??????
Thanks for a answer
On my car, I have:
Thanks for a answer
