vtec adjustment w/red button. ***not working***
Posted: Tue Jul 18, 2006 10:26 pm
by bottlefedgsr
ive tried it in dynamic and static mode but it does not adjust. am i doing something wrong im going off of the online users manual...... thanks in advance
Posted: Wed Jul 19, 2006 10:19 am
If you have the vtec point set in the ecu you cannot change it with the push button.
Posted: Wed Jul 19, 2006 10:42 am
by bottlefedgsr
does the reset work still cause the vtec is popping at 6500
Posted: Wed Jul 19, 2006 11:17 am
If the vtec point has been set in the ecu it cannot be reset using the push button. You will need to contact your tuner and have them reburn the chip with no vtec point set. This is not recommended as once the vtec point has been set after dyno tuning you should not be changing it.
Posted: Wed Jul 19, 2006 11:35 am
by bottlefedgsr
so basically it is only good for changing the other 3 things listed then.
