are these non-resistor plugs?
Hogie
Post by Hogie »
im running a cyberntion kit wit the 60-1 turbo with 1000cc injectors and hoping to turn the boost up, but every time i dialog, like previous other members the kmanager cuts out, it just stops dialogging and it says the ignition is off and everything loses connection, so i ahve to turn the car off and unplugg and replugg the usb, but this cut onlyh happens when i get on it into high rpms in second and higher gears.
im running the ngk BKR7E 6097
if these are not the right plugs i should go with, can someone recommend me to the plugs i should use (please include brand and part number)
Do you have a resistor box installed for the injectors?
Hogie
Post by Hogie »
im using "injector drivers"
Hogie
Post by Hogie »
so will these plugs do??
is there anything else i need to be aware of?
of yah bout much much fuel pressure should i put at the injectors?
50-60 psi??
The problem is the aftermarket injector drivers. You will need to remove that and install a resistor pack to run the low impedance injectors.
