how do i get psi to show in the table ?
Upperguy
Post by Upperguy »
i have it set to show psi but it is only showing mbar can anyone help?
Go to Options, settings, then go to the units tab.
Upperguy
Post by Upperguy »
ive done that and it still says Mbar in the upper right corner when im in positive pressure are of the map so does it always display the vacum units and never the boost?
Upperguy
Post by Upperguy »
anyone?
To see boost tables, click on Options and Show boost tables.
yakito
Same problem - help please!
Post by yakito »
I have the same problem, I changed the units to psi on the settings window and then selected the show boost table but still cant get the table to show psi values. This might be a dumb question as only one thread appeared on the search, but can somebody let me know how to change the units form mbar to psi on the table?...smanager version is 1.3.6.0.
Thanks in advance!
Go to Options, Settings, Units.
joeb
Re: how do i get psi to show in the table ?
Post by joeb »
Upperguy wrote:i have it set to show psi but it is only showing mbar can anyone help?
Do you mean when youre viewing a datalog ? I am having this same issue . Whenever i review a datalog it always shows in mbar instead of psi . Perhaps someone can chime in and help ?
hybridcivicls-t
Post by hybridcivicls-t »
options
settings
then click units. its the 2nd tab.
then in vacuum pressure the first box,
click "inch"
go to the next box pressure unit,
click "Pounds per square inch (psi)"
then click "ok"
be sure in the other box "vacuum unit base"
click absolute(increase from full vacuum)
"pressure unit base"
click "Atmoshperic (atmoshperic=0)
i think that should solve your problems, if its not your not doing something right
yakito
Still Can't
Post by yakito »
I must have something wrong here...can someone tell me (check the print screen)...I can't see the table in psi after the changes in the settings tab. Thanks again!
They must both be atmospheric, not absolute.
yakito
Not yet!
Post by yakito »
Still can't...I can only see vaccum on the boost tables, Does it has to be online for it to show psi?....Thanks for all the help.
Frankie
joeb
Re: Not yet!
Post by joeb »
yakito wrote:Still can't...I can only see vaccum on the boost tables, Does it has to be online for it to show psi?....Thanks for all the help.
Frankie
Agreed , im in the same boat .
Please post you calibration. It is possible that the columns have been re-calibrated to not have any boost columns.
