s200 J1 jumper?
9db85
s200 J1 jumper?
Post by 9db85 »
I got my s200 installed on my p72 at a computer repair shop and all the soldering looks good. My question is in the instructions I have it says use a extra wire to put in the j1 jumper location, The person that installed mine put one of the supplied resistors( the one with on line on it) in the j1 jumper location. I have put it in car but have not started it yet, just turned on the switch and the led don't flash it just stays on. Is this normal?
The reason I did not statrt the car is becasue my stock engine is still in car I have not had time to put my built motor in there yet.
Thanks,
J.Newman
That is a zero value resistor..it is the same as a piece of wire.
Until you actually try it, you will not know if everything has been done correctly.
