For the ECT reading in K-Pro, between what numbers are considered normal/safe on a turbocharged application? ANd what is considered overheating?
My temp gauge on my cluster doesnt work. I drove the car to my tuner shop to have some suff installed (including a Water temp gauge) and the ECT jumped as high as 230 (city + freeway driving). Today was the first time driving the car in the hot weather, around 100-102 degrees.
I am turbocharged so my manifold and turbo will make my engine bay a lot hotter. My headgasket is fine. I am not losing coolant and my resovoir bottle doesnt fill up or change. The ECT on a cool night is always steady at 183-186.
(If it matters, its a built k20a2 motor in a 2000 Civic with a Koyo Radiator (half size). manifold if a Full-Race sidemount with a GT4088R turbo)
What is considered safe/normal for the ECT reading? (turbo)
IT1ONBOOST
IT1ONBOOST
Re: What is considered safe/normal for the ECT reading? (tur
My turbocharged civic always seemed to run very hot during the summer and my friend's is the same. He runs his fan all the time and it still overheated. What he did was take the thermostat out and now it stays around 180. Ocassionally it goes up to 210+ but then it cools down quicker.
no thermostat = bad ideacrucian wrote:My turbocharged civic always seemed to run very hot during the summer and my friend's is the same. He runs his fan all the time and it still overheated. What he did was take the thermostat out and now it stays around 180. Ocassionally it goes up to 210+ but then it cools down quicker.
Ammm.. where I'm from, we don't believe in the thermostats. So that's your opinion. I won't encourage anyone to do it where the temperature of the weather changes though.kaj wrote:
yeah. just my opinion. how do you expect the water to stay in the radiator long enough to cool down?crucian wrote:Ammm.. where I'm from, we don't believe in the thermostats. So that's your opinion. I won't encourage anyone to do it where the temperature of the weather changes though.kaj wrote:
http://www.hondata.net/forum/viewtopic.php?t=1193
Running without a Thermostat is a very bad idea...it is there for a very good reason.
