looking for B18C JRSC + 240cc injecter Calibration
takashi
Post by takashi »
Any Calibration for B18C JRSC with 240cc orginal injecter? or Can I use B18C JRSC with RC 440cc injecter Calibration and just change Fuel Trim to 240cc?
You should not use stock injectors and boost...you will have major problems.
takashi
Post by takashi »
 Rally? I Didn't Know About It. But If I Don't Use Boost、 Is That OK?
Then why have a supercharger?
takashi
Post by takashi »
Spunkster, I have a question. Is JRSC engine make burn engine oil faster than normal engine? or maybe have problem my engine.
You should not burn oil because of a supercharger. It sounds like you have some kind of engine damage. This could be caused from running too lean.
NeriVtec
Post by NeriVtec »
If it is a B18c1 with a JRSC at 6lbs with stock injectors, will this work??
No, you should not use stock injectors as they will not flow enough fuel and you will not be able to add enough fuel and will run lean.
NeriVtec
Post by NeriVtec »
So there is no map that can be used until the injectors are put in?
ITR 1102
Post by ITR 1102 »
that is correct. what good would a map do you if your injectors will not work. even if you created a map with the stock injector size and have the duty cycle maxed out, you still wont flow enough fuel.
get the injectors like Spunkster said, then use the basemap supplied in the sticky portion of this forum found here. http://www.hondata.net/forum/viewtopic.php?t=4397
