kpro disconnects my usb
trvotypes
Post by trvotypes »
I am having an issue with the kpro program. ever since i updated it to the newer version i plug it in and then drive around trying to datalog and then the kpro manager says its disconnected and the ignition and all that is offline, is this a known problem, and what should i do?
SHould i reboot the program? anyone else having this problem
When you click on Help, and about, what is the version of the software you are using?
trvotypes
Post by trvotypes »
ill check again.. but i just recently updated it and i think it the 1.7
IT1ONBOOST
Post by IT1ONBOOST »
I have the latest version downloaded as of last SUNDAY June 18
Im having a similar issue of USB disconnecting.
When I disconnect the USB and plug it back up immediately after I have to go through the whole process of installing the drivers again for me to be able to get online with the ECU.
I just finished building the motor and this weekend will be messing with it again to get it road ready. I hope I don't have any problems on the road getting online..
P
I need My boosted Jelly beaNs
Have you uploaded a calibration to the ecu after installing this new version of software? If not, that could be the problem.
IT1ONBOOST
I have uploaded a Kal and same issue. I will try again this weekend
trvotypes
Post by trvotypes »
yes i have put a calibration on and it does the same.. im thinking of uploading an older version of the kpro manager to see if it does it, when i had it before it worked without a problem
Don't try an older version of software....that is not the problem and an older version will just give you more problems.
What spark plugs are you using (part number)?
trvotypes
Post by trvotypes »
i have ngk2668
IT1ONBOOST
I got the same plugs
What are your setups?
IT1ONBOOST
Right now I'm prepping for boost...
current setup includes
1000cc injectors w/resistor box
1:1 FPR
BDL Fuel rail
Intank Walboro
Return line
9:1 compression
NGK 2668
Current Kpro Version
Stock head for now...
Below is a screen shot of the window that pops up when trying to install USB drivers...I also get cannot find KproUN.exe wehn installing drivers.
BTW u want me to start my own thread? i dont mean to jijack this one. But it is similar usb issues
trvotypes
Post by trvotypes »
i am running
greddy turbo kit with frount mount
rc 550ccinjectors
3inch exhaust
IT1ONBOOST - you have a completely different problem...what version of Windows are you using?
trvotypes - What USB cable are you using? Does it have a bead at each end? THis problem is very common with Greddy Kits and we do not know why. My best guess is that it has something to do with the prtective wrap they use for the wiring harness.
trvotypes
Post by trvotypes »
im not sure what type of usb cable it is but its black, basically came with the hondata
