car starts, idles then stalls??need help
Posted: Wed Jun 07, 2006 10:59 pm
by boosted rsx
i just got k pro. i installed it and my car and i opened the calibrations for cn turbo kit w/ 550 injectors, and also stock calibrations but it will start idle real rough, the rpms are all over the place. my a/f guage is all the way on rich... i have no idea what to do, or how to cut down the a/f ratio. my car is turbo'd,w cybernations stage 1. what do i need to do?
Posted: Wed Jun 07, 2006 11:19 pm
by vtec racer
If you have a digital A/F gauge then it will read rich most of the time. Stay out of boost until you get it tuned. To get your car to idle bring the idle rpm up to around 950 rpm.
Posted: Thu Jun 08, 2006 8:59 am
by boosted rsx
thanks ill try that and ill let you know if it works..
Posted: Thu Jun 08, 2006 10:29 am
by boosted rsx
i tried that and messed around with the idle a little and it idles alot better now, thanks alot. but it stil stalls i have an error code of variable valve timeing and crank shaft sensor..but thanks for all your help......
