V1.2.1.6 (26 May 2006)
Posted: Fri May 26, 2006 3:32 pm
The main change is a much improved download function, which works with all the earlier uploads versions which I tried.
? Improved data integrity when downloading from the ECU which was uploaded with an old KManager version
? Allow KManager and SManager to connect to ECUs simultaneously
? Fixed datalogging problem when VTC is disabled
? Fixed nitrous operation on PNF ECU
? Added tip in ignition retard control to PNF ECU
? Added option to disable the idle valve for ITBs (PRB ECU only)
Use the built in 'check for updates' function in KManager.
Posted: Fri May 26, 2006 10:43 pm
by locash
Thanks Derek! The PNF group thanks you for getting around to that.. :)
Posted: Tue May 30, 2006 9:12 am
by Malaka
"Allow KManager and SManager to connect to ECUs simultaneously"
What is this for?
Posted: Tue May 30, 2006 12:21 pm
KManager would identify the s300 as a KPro, and vice versa, so we changed the USB IDs to fix this.
Posted: Tue May 30, 2006 2:23 pm
by Razathorn
Hondata wrote:KManager would identify the s300 as a KPro, and vice versa, so we changed the USB IDs to fix this.
Dohs! Somone coppied a h file ;).
Posted: Wed May 31, 2006 12:42 pm
by Malaka
OK, thanks.
Posted: Wed May 31, 2006 7:56 pm
by thesilverbullet
Re: V1.2.1.6 (26 May 2006)
Posted: Wed May 31, 2006 9:57 pm
by hatchbacKed
Hondata wrote: ? Improved data integrity when downloading from the ECU which was uploaded with an old KManager version
Installed this update and tried to donwload calib. from the ECU and I've gotten funky values for the Gear Comp>Gear ratios like 1=.0434, 2=47.104 and the fuel trim>inj. size value is 2000. I guess there are still some issues with data integrity downloads.
When installing these updates do I need to do Update Firmware on the ECU?
Posted: Thu Jun 01, 2006 5:49 pm
by thesilverbullet
thanks for the update. maybe this version should have been a beta
