What injecotrs to get for Hondata....RC?
Just wanting to know if there is a certain injector company that works very well with Hondata. I see Hondata sells RC but I want to know if there is another company that is better suited for Hondata. I am hearing that larger CC RC injectors (720cc and up) don't idle well with HOndata. I am planning on 450 horse and I want to make srue I have the injectors to run that. Thanks in advance for advice.
Injectors
RC injectors work well. We've got 1000 cc injectors to idle well on a 1800cc engine, 1200s in a 2000cc engine. Stay away from any injector which is not 2 ohms or 12 ohms resistance (e.g. the 6.5 ohm bosche injector).
Re: Injectors
I have 800cc RC Injectors. How do I know I don't have the Bosch ones you have specified?Hondata wrote:RC injectors work well. We've got 1000 cc injectors to idle well on a 1800cc engine, 1200s in a 2000cc engine. Stay away from any injector which is not 2 ohms or 12 ohms resistance (e.g. the 6.5 ohm bosche injector).
Edit, I think I am OK but here is a link to my spec sheet. PLease check out to make sure. Injectors are Keihin P&H 2.5.
Also, can you give me an idea on what I am going to have to set the fuel pressure at for these? 60?
