E85 calibration
E85 calibration
I am running a 2002 RSX-S engine with RC 550 injectors, IPSK2 cams, 4-2-1header, no cat, 3 1/2" short pipe.
Recently I've been running E85, that's 85% ethanol and 15% gas. I'm using the standard IPSK2 calibration with 75% increased fuel trim. Mileage sucks, but power "feels" good. My Lambda readings are in the .8 range at WOT.
Try at your own risk.
Del Long
Del Long
Nice to see someone else running the corn juice. Down here in KS, we aren't quite swimming in the stuff like IA, but it is available. I just polished off a couple tanks, got about 28MPG, (so far best gas MPG looks to be about 32) but still need to do a lot more tuning on the part-throttle maps.
I am surprised that you bumped the fuel trim 75%?? I only turned mine up 25% and was still running rich in a lot of areas. If you are light-throttle cruising at 0.8 lambda, that seems a little rich to me. I've been trying to trim down to 1.00 - 1.03 range for the light throttle stuff. 0.8 is good for WOT, though.
Corey
E85 fueled Acura RSX-S Turbo w/ KPro
∙ 12.5:1 CR ∙ Precision Billet 5857E @ 15psi ∙ OBX Sidewinder ∙ ID 1000's ∙ ACT XTSS ∙ OBX LSD ∙ Custom 3" Magnaflow SS Exhaust
Mine is a autocross only application. I have dropped the mix back to 65%. It runs so well there I haven't changed it, but plan to do more testing next spring.Corey872 wrote:Nice to see someone else running the corn juice. Down here in KS, we aren't quite swimming in the stuff like IA, but it is available. I just polished off a couple tanks, got about 28MPG, (so far best gas MPG looks to be about 32) but still need to do a lot more tuning on the part-throttle maps.
PS the car finished second in both D Modifed and E Modified at the SCCA SOLO Nationals.
Del Long
BongoBennie
BongoBennie
BongoBennie
It's worth noting that the wideband doesn't actually know what fuel you're running, so closed loop is really, just as before, trying to operate at stoich. It won't be the same 'actual' a/f, but the lambda will be the same. Basically, the a/f will be 14.7 on the read out, but that will not be the a/f, it will be the a/f if you had petrol in the tank. If the target a/f is 14.7, it should try to maintain 1.0 lambda, which won't really be 14.7 a/f, but it will be reported as such.BongoBennie wrote:are you driving in closed loop? if so, how do you adjust target ratio?Corey872 wrote: If you are light-throttle cruising at 0.8 lambda, that seems a little rich to me. I've been trying to trim down to 1.00 - 1.03 range for the light throttle stuff. 0.8 is good for WOT, though.
Wayne
BongoBennie
Just filled up today:
E85 - 2.39/gal, I get 27MPG = about 9 cents/mile
Premium - 3.09/gal, I get 31MPG = about 10 cents/mile
So I would call that a 10% savings. If you consider 27mpg "much worse" than 31mpg, I guess you got me there. I don't know about less power...With E85 at 105 octane, being able to tune to the full extent of the engine and turbo helps substantially, it's just a matter of putting in the right amount of fuel. You aren't tweaking the timing and boost around detonation from crappy low octane 'premium' gas.
I'm tempted to ask, Teamko, are you just re-stating rumors and wive's tales that you've heard or have you actually used E85 and not had good results?
Corey
many studies have been done to determine weather E85 is worth it.
www.fueleconomy.gov is one the government wants fuel efffeciency and less pollution... compare the fuel cost and numbers from vehicles that use e85 or regular fuels... the final value is always worse with E85.
and you have less power race cars don't use high octane or race fuel for a reason.
try racing an RSX with same mods as you... if the drivers are equal in skill you'll lose.
