Map sensor wiring help please
Djbower1
Post by Djbower1 »
Hi all,
I have just rewired my engine loom and now my car doesnt start. I think ive fried my map sensor due to it being wired wrong.
Please could somesone confirm what pins on the map sensor goes where.
Looking @ the sensor face on you have V G O which I assume are Voltage, ground and output.
What pin goes where:
Voltage (left pin on map) - D?
Ground (middle pin one map) - D?
Output (right pin on map) - D?
Thanks in advance.
Dan
scottishpol
Post by scottishpol »
Some details might help Dan!
Which car, engine, map sensor.....obd 1 I presume!
Voltage is a constant supply, test it with a avo meter
Check ground continuity, trace pin to ecu.
*EDIT* Check pins D17, D21 andD19.
