Using a wideband (Innovate and PLX) on K-pro?
Posted: Wed May 17, 2006 9:56 am
by Garrett_si
I had 2 wideband controlers with sensors
and I need to know where to chose the wideband sensor into the K-Manager
thanks for your help
Posted: Wed May 17, 2006 11:32 am
The K-Pro cannot use an aftermarket wideband. You must use the OEM wideband sensor.
Posted: Wed May 17, 2006 1:19 pm
by locash
It's too bad the OEM sensor is such a piece of junk. It would be nice to be able to use an aftermarket sensor and controller and input the data into the K-Mangler. Until that day comes, I use both.
Posted: Wed May 17, 2006 1:55 pm
by Garrett_si
the primary sensor is wideband I think
possible to tune with his AFR value?
Posted: Wed May 17, 2006 5:32 pm
locash was/is being silly.
The OEM primary is wideband, and can be used for tuning. It is not that sensitive at very rich AF ratios, but still works very well.
Joe, stop being silly. I've fixed your PNF nitrous control.
