OBD2b engine/ECU swap into OBD1 car
rsaeini
Post by rsaeini »
I am putting a B16A2 engine into my 95 Civic EX coupe(OBD1). The engine uses the P2T ECU(OBD2b). There is an abvious problem with the wiring.
How can I make it work?
Are there any conversion kit? If I use a conversion kit what ECU do I use, how does the conversion kit work?
Where can I get a conversion kit from?
Is there any way to get around that and be able to wire it up myself?
*PLEASE HELP*
rsaeini
Post by rsaeini »
will I be able to use a OBDI P72 ECU in place of the P30 ECU ???
95 vehicle / 96+ engine
Use an OBDI ECU - P28, P30, P72 etc. Sell/throw away/eat/burn the P2T.
