Exporting datalog files
TurboLS
Post by TurboLS »
When I export the datalog files, the only columns filled in are frame, time, rpm, speed, and map. All of the other columns are blank. Also, the speed appears to be off. I assume this taps the VSS, but I took this datalog merging onto the highway in a bit of traffic and there is no way I was going as fast as it says I was. Can anyone point me in the direction of the option to change which values are displayed in the columns in the CSV file>>? thanks.
TurboLS from Team-Integra.net
(703)919-2786 (C)
The speed units are kph. The other fields will be added for the next release.
TurboLS
Post by TurboLS »
Will any other columns be added? Such as ECT and IAT? I guess until the next release comes out, I will just have to guess some of the correction factors and then datalog at those temperatures to see if the estimates are correct.
(703)919-2786 (C)
TurboLS
Post by TurboLS »
OK, I just updated to V 1.1.4.0 and I thought that one had the extra columns filled in. Will they be in V 1.1.5.0 ?? I could really use them as estimation is only getting me so far. any ETA on the new release?? thanks.
(703)919-2786 (C)
