Vortech SC maps on the way? :D.
LiLOtaku
Post by LiLOtaku »
I was just wondering if there are going to be any Vortech Supercharger "basemaps" for the B16 or B18 engines available anytime soon. I plan on getting a Vortech within 3 months and it would be pretty handy to have some of these around ;).
Everyone at hondata has been very helpfull and I thank you guys for a great product.
Let's see those Vortech SC basemaps ;).
-LiLOtaku-
jbbauer
Post by jbbauer »
I second this! I'm getting a intercooled vortech SC for my b16A and all the SC basemaps are for the JRSC. I'm also looking into investing over $1200 into the hondata system with programmer etc. But I need a baseline to work from.
LiLOtaku's post was a year ago, so do I assume there will be none added for the Vortech?
drvtec99
Post by drvtec99 »
need a vortech base to work off of asap!!!!
drvtec99
Post by drvtec99 »
somebody's gotta have one
Silverbeast
Post by Silverbeast »
Due to the style and powerband of the Vortech, why couldnt you use a turbo car map? The Vortech is a turbo on a stick, I dont see why it would be a problem.
If it's an issue of getting the car to start, then your tuner should have supplied a basemap to get the car started and to them. If you are looking for a tuned map that is "safe" to boost on, good luck. I dont know any tuner that is willing to send a map and just say, yep it worked on this one car this one time at this one place. There are too many variables to take into consideration.
seen4ever
Post by seen4ever »
Silverbeast wrote:Due to the style and powerband of the Vortech, why couldnt you use a turbo car map? The Vortech is a turbo on a stick, I dont see why it would be a problem.
I provided drvtec with a basemap off a turbo car, yet I was more wondering about the load differences between a supercharger and a turbo.
2004 Infiniti G35c
1992 Honda Civic CX
2005: 11.2@133 cracked sleeve
2006: more power :)
Any basemap provided will be to just get the car started and onto the dyno. DO NOT ATTEMPT TO BOOST ON A BASEMAP!
IT will need to be properly tuned on the dyno to be safe for the engine.
drvtec99
Post by drvtec99 »
just want a Vortech base map for b16
Silverbeast
If your tuner knows what he is doing a "basemap" should have already been done. If you cant afford to be tuned right now, the tuner should at least burn a basemap with the boost cut enabled at 1psi. If nothing else, put stock injectors back in it and either a stock map or stock ECU and DO NOT BOOST until you get it to be tuned.
drvtec99
Post by drvtec99 »
no one here can respond to a simple answer with out some stupid newbie responce
drvtec99
Post by drvtec99 »
Silverbeast wrote:If your tuner knows what he is doing a "basemap" should have already been done. If you cant afford to be tuned right now, the tuner should at least burn a basemap with the boost cut enabled at 1psi. If nothing else, put stock injectors back in it and either a stock map or stock ECU and DO NOT BOOST until you get it to be tuned.
Did I ask all of this, umm no. but I appriciate u trying to help he out, but I just want a vortech map to work off of. But I guess thats too hard to ask for around here.
