is there any help for my 98 lude
i have a 98 prelude with an F-Max turbo system and the dyno guy is telling me i need an hondata system to get the horsepower out of my car.the system came with two extra injectors so i have a total of 6 he also said to go with bigger injectors if feels to be running lean at 120 mph but someone told me it was the factory computer shutting off will the hondata system help what do i need to do
How much boost are you running. Anything over 10 psi and the stock map sensor will not work. If your running high boost, you probably do need bigger injectors. My father-in-law dyno's cars and he says all cars run lean at top end. You should get the bigger injectors. Ask the guy who dynoed your car, what size to get. He should know more than I do.
