Dual stage nitrous issue / questions
Posted: Wed Apr 19, 2006 8:57 am
I'm implementing a dual stage nitrous system on my RSX and I think I have found an issue with the E20 output.
When I use E20 to control my 2nd stage the menu says gnd=on, however it appears the actual implementation is reversed. This output is always gnd, even when the nitrous is disarmed. By selecting "invert output" the function bahaves as I'd expect for gnd=on (i.e. only supplies current sink to activate relay when nitrous is armed and parameters are met)
I'm using kmanager 1.2.1.1, and I'm attatching my cal.
Questions:
When both nitrous 1 and nitrous 2 are active are values such as retard and fuel additive, or will 1 setting override the other?
Questions:
