need help with a boosted + built B18C1
Posted: Sat Apr 08, 2006 12:52 pm
by Valjoker
need some help with a basemap for my setup
Chassis Integra LS (formerly automatic)
P72 ECU
B18C1 block Sleeved +bored out to 2.0L
Forged internals Pistons,rods,crank
GSR Head Ported + Polished 5 angle grind
Crower valve assy and Turbo bumpsticks
Skunk2 Adjustable cam gears (both set at 0)
Edelbrock VictorX intake manifold
Walbro fuel Pump
AEM fuel Rail
1000cc Injectors
Turbonetics T3/T4 turbo kit w/ intercooler @ 15psi
Rebuilt GSR tranny w/ quaife helical LSD
no ignition mods (yet)
greddy EVO2 exhaust
Posted: Sun May 07, 2006 4:17 pm
by TurboGSR96
use the SC61 map below, I have a very similar car with similar mods and my car started. I just had to change the injector size to 1000cc which you will have to do also and depending on what map sensor you are running you have to change that too. Change those and get to a tuner.
Posted: Sun May 07, 2006 9:01 pm
by Valjoker
TurboGSR96 wrote:use the SC61 map below, I have a very similar car with similar mods and my car started. I just had to change the injector size to 1000cc which you will have to do also and depending on what map sensor you are running you have to change that too. Change those and get to a tuner.
thanx man... but weres the map?
Posted: Mon May 15, 2006 4:03 pm
by TurboGSR96
look in the calibration section in this forums.... its the bottom one, says something like 440cc SC61
