Starting problems
Posted: Fri Apr 07, 2006 10:23 am
'01 ITR B18c5
98 spec itr base map
w/ inverted purge valve
(spunkster's cal. post)
I've had my S300 for about a month now. It's starting to get hot and humid. In the afternoons I'm having trouble getting my car to start with the S300. I need to rev to 2000rpm for about a min. so that the car will stay running by itself. If I don't do this it will die immediately after initial start up. I also have problems getting the car started after refueling. The last three times I refueled the car had similar symptoms as the initial start up problem. The last time I filled up I reved to 2000rpms and waited until it would run by itself and then began to drive. As I left the service station the cars rev limiter was set at 5000rpms and the check engine light came on. Fearing something bad I pulled over and reinstalled the stock ECU. When I got home from work I reinstalled the S300 and the CEL was gone and the calibrations were back to normal. Car still running fine. I apologize for not having much more info. Next time I go to fill up; I'll bring my PC so I can check more in depth. Does anyone have a problem similar to this? Any suggestions as to the problem? Thanks.
Once I get the chance I will let you know what the CEL was.
