multiplex
Posted: Thu Apr 06, 2006 7:54 am
by ekek888
forgive me for asking, what functions are multiplexed? im asking bc when i disable the multiplex in kpro, the water temp wont work!! ive done a swap and had the engine harness cut / lengthened etc, this is a JDM dc5r btw. thanks
Posted: Thu Apr 06, 2006 8:50 am
Water temp, charge light and A/C control.
Posted: Thu Apr 06, 2006 7:20 pm
by cstyleaccord
yeah i was having that same question as well..but i also have another question...the 03 accord k24 has "can H(can communication signal high)" and "can L(can communication signal low)" when i was looking at the pinouts diagram of the ecu. is it the same thing as the multiplexor?
the accord also use "nc (countershaft speed sensor)". so is it neccessary?
Posted: Fri Apr 07, 2006 8:46 am
The RSX multiplexer is incompatiable with the CAN bus found in the accord.
Posted: Fri Apr 07, 2006 9:57 pm
by cstyleaccord
Hondata wrote:The RSX multiplexer is incompatiable with the CAN bus found in the accord.
sorry for being a noob, but what does the "CAN" bus control?
Posted: Sat Apr 08, 2006 12:39 am
by projekZERO
theres several can lines on these cars.
B CAN (body)
F CAN (fuel system or pgmfi)
K CAN (dlc)
and some cars have other CAN lines such as UART or G-NET.
a CAN line is basicaly a communication line between control units or MICU's (multiplexers)
digital signals are transmitted back and forth on these lines. its the way all the control units talk to eachother.
Posted: Sat Apr 08, 2006 8:16 pm
by ekek888
Hondata wrote:Water temp, charge light and A/C control.
this will be combined into one wire, can pls tell me what color is it or where can it be found. thanks
Posted: Sun Apr 09, 2006 3:48 am
by cstyleaccord
pin 24 of connector E, its a yellow wire
Posted: Sun Apr 09, 2006 4:16 am
by ekek888
thanks
Posted: Wed Apr 12, 2006 1:30 am
by cstyleaccord
can i possibly run both stock accord ecu and ep3 kpro ecu at the same time? just like aem does with their 1030 model. can i just wire it off from the harness to new connectors to just control the "vss" and the can system so i would be able to control my a/c, gauges and what not? if thats possible, how would i about to do this..which wire (pinouts) are needed to do this? please help me out. thanks
