Voltage VS. Air/Fuel Ratio Charts for Stock K-Series PHO2S.
sander
Post by sander »
Hondata,
Do you have the chart handy, Id like to chart to calibrate my wideband (Innovate) to read like the stock K series unit.
Thanks!
-sander.
learning.
Which chart? There is no relationship between voltage and lambda for the RSX o2.
sander
Post by sander »
Hmm,
I would have imagined that the stock ECU (PRB) would have a voltage chart, to interpret the voltage readings in to Lambda values.
For example the PLX reads
0.00V = 9.99 AFR
5.00V = 19.99 AFR
or the FJO
.85 V = 9.996 AFR
1.20 V = 10.996 AFR
1.60 V = 11.995 AFR
1.95 V = 12.995 AFR
2.30 V = 13.994 AFR
2.50 V = 14.700 AFR
2.65 V = 15.994 AFR
2.80 V = 16.993 AFR
3.10 V = 20.0 AFR
Im just curious how Kpro intreprets the O2 signal to read AFR/Lambda off of the stock 02 unit if there is no defined relation ship between voltage and AFR/Lambda.
Thanks guys!
-sander
learning.
menfou
Post by menfou »
The stock PRB ecu not read voltage, but current.
sander
Post by sander »
Ok that was the missing link i needed.
-s
learning.
