K-Pro and Accord Euro K20A6
CivicVTi
Post by CivicVTi »
Hi. Does anyone know whether I can fit a K-Pro in a '03 Honda Accord Euro with K20A6 engine (i-vtec, 155hp, 2.0lt). The car is the same as the Acura TSX but with K20 instead of K24 offered in the US.
If yes, I guess the max cam advance is limited to 30deg, right?
CivicVTi
Post by CivicVTi »
ECU is RBA
Dominic..
Post by Dominic.. »
you cannot use Kpro.
also you cannot use other ecu like PRA,PRB,etc,
becouse Accord ecu control many internal function, like climatronics,etc,
so if you change ecu, you lost these function.
www.Ecu-Performance.com.pl
Euro CTR Boost - 1/4 12.066s ET
eurocl9
Post by eurocl9 »
how about running pararell ecu on k24a2/ Tsx with K-pro? is this possible ?so the k-pro only work for the engine and the stock ecu work for ac, etc
This is not something that Hondata supports, and would not recommend attempting.
