dealer reflashed it back
Posted: Fri Mar 31, 2006 7:20 pm
by nicholas moffett
I just got a new ecu reflash for my rsx I took it to the dealer because it was under warranty and I thought a motor mount may be broke. I pritty sure they reflashed it back to the stock setting. What do I do I just got the dam thing.
Posted: Mon Apr 03, 2006 1:24 pm
It is unlikely that the dealer could reflash the ECU as their software would tell them the ECU was already a more recent version. What year and model is your RSX? If you have a type S then you should be able to test the ECU by seeing where the VTEC point is. Note that stock tachs are typically 200 rpm at 5000 rpm so the 5200 rpm VTEC will read at 5400-5500 rpm, but a stock ECU will be close to 5900 rpm (on the tach).
