Clutch Switch, ground or positive
crucian
Post by crucian »
I have been looking all over on how to install the clutch switch for the S300. All I find is the installation for the S200 with an interface box. My questions is, do I run ground through the clutch switch to ECU, or do I run a 12v wire? Can't seem to find that answer no where. Thanks!
You need to look at the input used in SManager, and then refer to the manual to see how it is normally wired. eg if you use the PSP input, then this switch goes to ground to activate it.
crucian
Post by crucian »
Thanks for the quick response!
