89 crx with a 90 b18a1 obd0
mrjuicie35
Post by mrjuicie35 »
89 crx with a 90 b18a1 obd0 i have bought the new obd1 dizzy, bought the new obd1 converstion wire kit. and the convestion kit for the dizzy from obd0 to obd1. i have a p06 ecu obd1 wired up for hondata. i also have the s200 with boost and datalogging. how do i hook up the parts to run correctly. hooked up the parts went to start and it misses, backfires, and revs up slow only to 3 or 4 grand. need help thanks confused.
Are there any arror codes?
mrjuicie35
it back fires it also misses really bad. the only codes so far are vtech spool and psi. i also have to hook up the wires that are seperate on the convestion harness. i don't know where they go.
I would suggest contacting a shop that is familiar with doing engine swaps for some assistance.
BA
Post by BA »
Did you change over your distributor from ODB0 to OBD2?
