Gear comp
Maverik
Gear comp
Post by Maverik »
Hi!
I've a K-Pro installed on a ECU type PRA (European Civit Type R). Is it possible to change the tables for fuel and ignition compensation and gear ratios? If so, how?
Have you installed the KManager software and taken a look at the options in it?
Maverik
Gear comp
Post by Maverik »
Yes I have.
In practice, once I've opened my calibration file with KManager, I go to Parameters and then Gear Comp but I cannot modify the tables that are there..
Am I doing something wrong? Do I need to activate some options?
Can you post the calibration you are trying to use? Try going to File, New and using one of the base calibrations, can you now see and edit the gear compensation?
Maverik
Gear Comp
Post by Maverik »
I tried to do what you suggested, but it didn?t work. Attached the calibration file I?m trying to modify.
Make sure you are using the newest version of sftware by going to help and selecting Check for updates. The current version is 1.2.1.3
Maverik
Gear Comp
Post by Maverik »
I'm using version 1.2.1.3, but I also tried the beta version 1.2.1.5 without any luck..
Strange, because the same versions here with your calibration are working perfectly. Can you send a screenshot of exactly what you are referring to.
Maverik
Post by Maverik »
The problem was on my laptop: on my desktop KManager was working OK.
I've formatted my laptop and reinstalled all programs and everything is working fine.
Thanks a lot.
