Started engine with slight problem
Posted: Tue Feb 21, 2006 7:22 pm
by jordonking
Hello,
I've got a 95 Honda Accord. I installed an H22a that I've built. It's going to tuboed later so I lowered compression to 9.2:1 and I've got 550 cc injectors installed for right now. I'm running a P28 with S300 system. I uploaded the prelude basemap and I'm trying to tune, but when I start datalogging I click on the show datalogged lambda and I get no A/F ratio. So I'm kinda stuck in that I don't know where to go with my tuning. As far as the wideband wiring I've got an LC1 wideband with aux wideband output wired into ELD (it is checked in the settings) and the narrowband aux output wired into factory O2 input. I did cut the ELD wire to fusebox.
I probed the Wideband input and I am getting voltage. Any help would be greatly appreciated.
Thanks,
Jordon King
Posted: Wed Feb 22, 2006 11:19 am
When you datalog are you getting any wideband readings? Have you changed the settings in the software to use the ELD input for the wideband signal?
Posted: Wed Feb 22, 2006 12:44 pm
by jordonking
Not getting any readings at all and I do have use ELD for lambda checked in software.
Posted: Wed Feb 22, 2006 1:03 pm
Have you entered the calibration numbers?
Posted: Wed Feb 22, 2006 1:19 pm
by jordonking
I entered 0.00 = 7.35 5.00 = 22.?? I believe. I entered the specs that they said to for the LC1.
Posted: Wed Feb 22, 2006 3:37 pm
Do you have ELD disabled in Misc?
Posted: Wed Feb 22, 2006 4:51 pm
by jordonking
It is disabled. I think I tried it enabled as well.
Posted: Wed Feb 22, 2006 5:33 pm
if it is disabled it will not work.
Posted: Wed Feb 22, 2006 5:47 pm
by jordonking
I'll try tomorrow to be sure and let you know. Thanks for responding so quickly. I hope that does it.
Posted: Thu Feb 23, 2006 9:19 am
by jordonking
OK. I enabled ELD and when I turn ignition to on position in Lambda overlay I get 22.00 afr in col 1 row 1 naturally, but when I start vehicle I'm not getting any other readings. Another thing is that instead of having one cell highlighted in lambda overlay I have 4 cells grouped together with no readings though. I also switched on the sensor overlay settings to ELD to see if that would work and did not change anything.
Posted: Thu Feb 23, 2006 10:30 am
Somehow you have something incorrectly wired or you have a setting incorrect. You will need to double check everything. You might find
http://www.hondata.com/techwidebandtuning.html useful.
Posted: Thu Feb 23, 2006 5:29 pm
by jordonking
I think I just may have found some of the problem. On Lambda overlay there's a minimum throttle requirement of 0 and I think my TPS was at -1. I'm gonna adjust that tomorrow and check again.
Posted: Sat Feb 25, 2006 1:12 am
by jordonking
Well I the wideband is reading it just takes a few seconds after engine is started until it starts logging lambda for some reason. The reason it wouldn't overlay is because my TPS was out of range. I still have for cells highlighted instead of one, but it must be normal, cause it's that way on my laptop and when I downloaded onto my home pc I get the same thing 4 cells highlighted in upper left of map. Once I start engine I have four highlighted cells bouncing around. Is this normal? And has anyone had a problem with their Honda Idling up and down while warming up? It was doing this before I installed the new motor with new IAC so I'm thinking maybe a vacuum problem.
Posted: Sun Feb 26, 2006 5:37 pm
by jordonking
Well fixed idling problem, it was the Fast Idle Thermo Valve. On my maps before I even start datalogging I have four cells highlighted instead of one. Once I start datalogging all 4 cells are moving around with RPM and Manifold Vacuum. Is this normal? I'm assuming it is because I downloaded another copy of Smanager on home PC and I have the same thing 4 cells highlighted, but when I'm reading tech files from hondata I see in their screenshots only one cell highlighted. Maybe a glitch in new version?
Posted: Mon Feb 27, 2006 10:43 am
4 cells is normal
