help with calibration
contectr
Post by contectr »
HI
i have a euro civic type r with small modify..
airbox modified hondata with k&n filter and cold air intake
hondata gaskest
wire ground
throttle body bored by me
exhaust central pipe without silencer and final pipe with silencer 60mm
i see the cam anglde composite dyno sheet, i can use it for create a calibration for my modify?
Honda Ep3 stock k20a2 jrsc
contectr
Post by contectr »
help?! :?: :?: :?:
Have you dynoed the vehicle? What is the origin of the cam angle maps?
contectr
Post by contectr »
hi hondata..
i don't have dynoed my car..because in italy all the dyno are not really...
i have create my map and i have in a dynostreet tune 228 cv at 7700 rpm but i think more cv it's possible?
do you want to see my actual map?
contectr
Post by contectr »
at cruise the hondata guide say set the cam angle at 30? for the best power, torque, emission...
it's right?
i have read in clubrsx forum, the best is set 20? at cruise...?!?
At part throttle there is little difference between 20, 25 and 30 degrees in terms of emissions, power, economy. Use 25 degrees if in doubt.
contectr
Post by contectr »
ok for the best power 20??
When the vtec kick on it's good have a/f little rich for power?
