injector size 2000 ??
Posted: Fri Feb 17, 2006 4:31 pm
by ourboy
I downloaded the map from my k-pro today and it seems to have been tuned with a older verison of kmanager as some of the values are very strange..
ie-injector size is 2000
even though 650 are fitted
my car is running fine
is it just a matter of changing these setting and uploading the new settings
I'm new to this all so any help is appreciated.
Re: injector size 2000 ??
Posted: Fri Feb 17, 2006 5:09 pm
by Razathorn
ourboy wrote:I downloaded the map from my k-pro today and it seems to have been tuned with a older verison of kmanager as some of the values are very strange..
even though 550 are fitted
I do not work at hondata.
Downloading the calibration is almost always a bad idea. Do not upload that calibration or your calibration on the ecu will be lost. Whenever I am forced to download a calibration, I always double check it. I've seen calibrations downloaded that had 65535 fuel units in all of the tables. What happened to you is the download feature displayed it's normal lack of ability to work well. Downloading your calibration from k-pro should be a last resort. When you do it, double check each and every parameter and every table to make sure the values look sane. If any are wrong, repeat the download from k-pro. Do this until you get a calibration that everything looks right in.
If you upload that calibration, your car will probably not run at all. If at all possible, get the calibration from the tuner who tuned your car instead of from the k-pro.
Posted: Fri Feb 17, 2006 5:10 pm
More than likely the calibration was curupted whe downloading form the ecu. We do not recommend ever downloading from the ecu. IT is much better to keep the file on your laptop.
Posted: Fri Feb 17, 2006 5:19 pm
by ourboy
thanks for the fast reply
I will now try and get the calibration from my tuner
thankyou.
