B18Csupercharger 440 injectors
HondAcura
Thank you
Post by HondAcura »
ramirez8583
Post by ramirez8583 »
will this work for a t3t4 turbo with 525 injectors???
ramirez8583 wrote:will this work for a t3t4 turbo with 525 injectors???
No
C_Rock77
Post by C_Rock77 »
Is this the same calibration as the one that comes with the S300, itself?
yes
MyLilCivic
few questions
Post by MyLilCivic »
Just to make sure.
This is the map for the J-spec ITR?
I noticed that you use the RC 440 injectors will i be ok if im using the precision 440 injectors i am also using a 190 fuel pump. What do i set the fuel pressure to on the regulator and also timing?
and if i need to use a different map can you please send the link were i need to go.
I just want to have this to start the car and be abler to drive it safely before the tune.
PS this is on a MVM stepper pulley as well 9 to 10psi boost
It is for a B18C5. Stock fuel pressure regulator. Walbro 255 pump. Stock ignition timing.
