Hondata fitment for D14Z6 engine
jpsmodifications
Post by jpsmodifications »
Hi
Will the Hondata S200 fit an EP1? D14Z6 Engine?
If not what will??
Regards
Chris
The s200 only works with OBDI engines or OBDII with wiring adapters. If the EP1 uses a direct ignition setup then the s200 will not work. You need to see if a EP3 ECU will work, and then use a KPro with EP3 ECU.
