B16A JDM OBD0, want a s300 on a obd1 ecu, which ecu ?
camshaft
Post by camshaft »
Hi guys..
I have a JDM OBD0 B16A that orginally was running a PR3.
Upgraded to a p28 running a s200...
Now I want to upgrade to a S300 and want to know which ecu is the best choice ? My s200 on the p28 is being sold...
So what is the best choice ?
-p28 or p06 or p30?
I guess a big question is if I want to use the factory knock sensor ?
thanks for all the help
cam
It has to be an ecu...the choice is up to you...if you want knock control, you need an ecu that supports this. There is a complete list of the ecu's at: http://www.hondata.com/ecus.html
camshaft
Post by camshaft »
Thanks Spunkster
I was told that the knock control circuit was calibrated to each engine type. So for a B16A using a P30 would be the ecu and using a P72 won't be a good idea.
Then again the stock knock control was for a stock engine. And that keeping it wasn't the best idea on a modified engine. And using a aftermarket system would be a better idea.
But I think my biggest question was...
So if I get a P06 how much more is it going to cost to have it upgraded so it does Vtec.
Compaired to if I just purchased a P28 that has Vtec already.
thanks
cam
Hondata does not convert non-vtec ecu's to vtec.
I have the complete list of the resistor differences between knock boards. I personally have 3 b-series cars, one turbo, one supercharged and one NA...all using p72 equivalents with the knock sensors enabled.
scottishpol
Post by scottishpol »
Would you be willing to share the resistor differences?
camshaft
Post by camshaft »
Thanks Spunkster
So with a S300 install on a P06 the regular install is done http://www.hondata.com/s300socketing.html
And the P06 will be able to activate vtec if my wiring to the ecu is correct?
cam
Spunkster wrote:Hondata does not convert non-vtec ecu's to vtec.
No, a p06 is non-vtec and will not activate vtec.
Knock Board resistor locations:
(All resistors are 100 Ohms - Brown, Black, Brown, Gold)
US P61 - None
US P30 - R15
US P72 - R11, R15, R16
JDM P30 - R12, R15
JDM PR3 - R15 (OBD1)
JDM P72 - R11, R15, R16
JDM P13 - R15
JDM P14 - R15
scottishpol
Thanks spunkster, I have been trying to find out the different locations for a while now. Greatly appreciated(sp?).
Sorry for jacking your thread camshaft.
Masta_Cutz
Post by Masta_Cutz »
Spunkster wrote:Knock Board resistor locations:
US P61 - None
US P30 - R15
JDM P30 - R12, R15
JDM P13 - R15
JDM P14 - R15
Spunkster, by this would you ,mean that by removing or adding resistors to the locations would change the calibration of a knock board?
i.e. re-calibrating my p72 knock board to that of a P13 H22A spec board?
or can i simply swap knock boards for the same effect?
deafy
Post by deafy »
US P61 - None
US P30 - R15
JDM P30 - R12, R15
JDM P13 - R15
JDM P14 - R15
What would the resistors need to be for a usdm h22 motor using p72?
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
