LSvtec Basemap (RMS Help)
Djbower1
Post by Djbower1 »
Hi all,
onto my na car now...
Has anyone got a base map for a LSVTEC???
B18C Bottom end 1997cc 12.0:1
B16A Head 316/318 Cams
all your normal head stuff done eg. 3 angle valves ect. (JG HEAD)
fuel pressure @ 45psi with RC440cc inj
If any one has got a good staring point i would be realy grateful.
Djbower1
Post by Djbower1 »
19 views and no reply
Someone must be able to help.... please
Thanks in advance
tboostdsi
basemap
Post by tboostdsi »
hey, have you tried the b16 greddy basemap...try that and see how it runs. i have a b18c5 w boost and i used the b16 greddy map. that seemed to work the best. at least this will get you started. if its too rich, load the b16 greddy map and maype do the fuel trim a little bit or change the injector size on the fuel trim.....make sure you have a wideband if you are altering the fuel trim and injector size.if you dont have a wideband, i wouldnt do any of this. take it to a tuner........good luck.
CivicVTi
Post by CivicVTi »
The guy does not have a turbo car.
I suggest you use the stock ITR calibration with the following changes:
1. Adjust injector multiplier for your injectors
2. Readjust them for added displacement (actually steps 1&2 are done together)
3. Reduce timing on all maps. 2-4 degrees is best
This should be OK to let you drive the car. Leave it in closed loop for added safety. You can also increase WOT fuelling just in case. After this, tune your car as soon as possible!
RMS
Post by RMS »
'email me.
are the injectors sat or p&h?
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
Djbower1
Post by Djbower1 »
RMS wrote:'email me.
Email Sent..
Djbower1
Post by Djbower1 »
Big Thanks To RMS for basemap ;)
