s300 help
Posted: Fri Jan 27, 2006 12:29 am
my car after installing honda is running somekind of safe mode..
rev limiter is at 4k..
CEL is on..
when i check my codes the srs light blink till i take the jumper out..
does not tell codes..
i can connect to the ecu and load maps but can not read sensors..
green and red light stay on..
i did mess up 2 tracks on my ecu but fixed it..
all the pins that have tracks i can follow are ok..
would be helpful if someone made a guide to testing if all your pins have a good connection
ex.. XX pin on IC4 connects to XX pin on IC3
that way people could be sure all pins are connected
also if i did mess up how can i buy the pins and the small chip..
don;t think i could get them out
CEL is on..
