Page 1 of 2
KManager V1.2.1.3
Posted: Thu Jan 19, 2006 4:52 pm
V1.2.1.3 (19 Jan 2006)
- Fixed 2d & 3d graphs not showing the table selection
- Added target idle lambda to the PNF and PND ECU
- Added countershaft driven speed sensor to the PND ECU
- Increased o2 sensor internal resistance error threshold from 40 to 50 ohms (P0134 DTC)
The last change might help people who have had P0134 error codes. These are generated 90 seconds after a cold start and seem to be caused by a change in exhaust gas temperature at the o2 sensor from stock, usually as a result of a race header or a turbo acting as a heat-sink.
Posted: Tue Jan 24, 2006 6:51 am
by DC5RK20A
Loaded up 13 and it appears to be taking care of the 1034 error, as I have not gotten it yet since loading up the program earlier today. At least so far so good. I'll know in another 7 hours when I leave for work in the moring as for sure the engine will have a cold start. Good job guys. Will keep you informed.
Posted: Tue Jan 24, 2006 10:06 am
by i vietec
When will PND ecu have TPS Ignition Retard?
Posted: Tue Jan 24, 2006 1:14 pm
i vietec wrote:When will PND ecu have TPS Ignition Retard?
We've added this - redownload the beta.
Posted: Tue Jan 24, 2006 3:51 pm
by i vietec
Thank you sir
Posted: Wed Feb 08, 2006 9:09 pm
by kornsined
everytime i download the file i get a corrupt setup file message when i try to install it.
Posted: Wed Feb 08, 2006 9:34 pm
by kornsined
n/m it finally worked. weird....
Posted: Tue Feb 21, 2006 1:40 am
by portandpolish
I've noticed since I've downloaded ver. 13, (Increased o2 sensor internal resistance error threshold from 40 to 50 ohms (P0134 DTC)), I'm still getting a CEL after the 90 seconds. Here's the scenario, It comes on when I've driven the car, after, I would leave it for a couple of hrs, where when I restart the car, it's still slighty warm. After 90 seconds up pops the CEL. By the way I have a new o2 sensor, bought directly from Acura. Pls assist. Thank you.
Posted: Tue Feb 21, 2006 3:46 pm
Is the exhaust system stock?
Posted: Tue Feb 21, 2006 9:23 pm
by portandpolish
Hondata wrote:Is the exhaust system stock?
I currently have Toda Race Header feeding into 2 7/8 inch downpiping, magna flow 3 inch resonator into 3" magnaflow muffler. (custom made)
Posted: Wed Feb 22, 2006 9:27 am
Is there a cat? Have you disable OBDII? What exact error code do you get?
Posted: Wed Feb 22, 2006 5:37 pm
by portandpolish
Hondata wrote:Is there a cat? Have you disable OBDII? What exact error code do you get?
Ummm? Cat? I'm just a bit puzzled as to the question, I run w/ a Toda race header, which doesn't come w/ a Cat, the error code is the same error code (P0134 DTC) some of us have been getting which is why the threshold has been increased, my suggestion would be to maybe increase the threshold 50 to maybe 60 ohms? I'm not sure? Again this code doesnot occur on a fresh startup, only after the car has been running for a while, I let it sit for let say 45 min to 1hr, Restart the car, (it is slighty warm) let idle or even drive it, after 90 Second thereshold "CEL".
Posted: Thu Feb 23, 2006 2:01 pm
The increase from 40 ohms to 50 ohms should give plenty of overhead. Download the latest KManager (even if you think you have the latest version, please just go through the process again), update the ECU and then send use a datalog from a cold start and then when the error occurs.
Posted: Fri Feb 24, 2006 6:47 pm
by thesilverbullet
port-man, just turn all the sensor shit off (OBDII, P0134, P1167) that's why the options are there... i never get CEL's!
Posted: Sat Feb 25, 2006 7:16 pm
by portandpolish
thesilverbullet wrote:port-man, just turn all the sensor shit off (OBDII, P0134, P1167) that's why the options are there... i never get CEL's!
The only prob, is that I wouldn't know my A/F. With it turned off I'm assuming I would be in open loop all the time, reading off of my fuel tables instead of relying on my O2 sensor. Which is why it's there. LOL
