Page 1 of 2
Problems with S300/PLX M-300
Posted: Mon Jan 16, 2006 4:48 pm
by Shadow!
I use S300 in P72 USDM and wideband lambda PLX M-300 with digital indicator.
Situation :
H22A base map,
S300 Ecu editor in datalog mode,
value on M300 indicator =~14.7,
but in S300 Ecu editor AF = ~11.00 ! why ???
The version of S300 ECU Editor V1.1.1.0
Posted: Mon Jan 16, 2006 5:38 pm
WHat are your settings, what input to you have selcted on teh Hondata for wideband, and what output are you using on the M300?
Posted: Mon Jan 16, 2006 9:25 pm
by Djbower1
Is your power and ground close to the ecu???
I use D22 for the ground even tho i was told it would mess stuff up but my M300 is perfect.
My M300 reads the same as my tuners Motec wbl.
Hope this helps
Dan
Posted: Mon Jan 16, 2006 10:16 pm
by kaj
Djbower1 wrote:Is your power and ground close to the ecu???
Hope this helps
Dan
same question for you:
Spunkster wrote:WHat are your settings, what input to you have selcted on teh Hondata for wideband, and what output are you using on the M300?
Posted: Mon Jan 16, 2006 10:19 pm
by Djbower1
as soon as photobucket comes back online ill post detailed screenshot
Dan
Posted: Mon Jan 16, 2006 10:23 pm
by Djbower1
Oh yer... removed std o2 sensor using nb output on m300.
Posted: Tue Jan 17, 2006 12:29 am
by Shadow!
Thanks guys for help. I will check the connections and settings.
Posted: Fri Jan 27, 2006 12:23 pm
by Shadow!
I solved my problems, thanks.
Can I use H22A stock map from Hondata in closed loop ? Or it's not smart usage ? My first target with S300 - fuel economy&good response map (for city cruising) for my ~stock H22A in Civic EK.
H22A stock map looks little strange for me... 450cc current injectors, +15% overall trim, why ? I use stock JDM 340cc injectors.
Posted: Sun Jan 29, 2006 12:29 pm
by TheKingPin
Yeah, just go to fuel trim in the parameters section and change the fuel injector size to 340 or so. It'll work fine. Thats what I'm doing right now until I buy my wideband.
Posted: Fri Feb 03, 2006 10:12 am
by Shadow!
TheKingPin wrote:Yeah, just go to fuel trim in the parameters section and change the fuel injector size to 340 or so. It'll work fine. Thats what I'm doing right now until I buy my wideband.
Thanks. I did it. From the third attempt :oops:
New problem
Posted: Tue Feb 28, 2006 1:47 am
by Shadow!
Close loop,
idle,
ECT 96'C
wide lambda connected via ELD
ELD disabled
in settings choosed PLX M-series
AF on PLX meter 14.67
AF in SManager 15.16
difference permanent
Posted: Wed Mar 01, 2006 7:48 am
by Marlon88
Shadow! , have you try making the ground wire of the PLX as close to the ECU as possible ?
Posted: Wed Mar 01, 2006 7:54 am
by Shadow!
Marlon88 wrote:Shadow! , have you try making the ground wire of the PLX as close to the ECU as possible ?
Yes, I connected PLX ground wire to ECU pin D22.
Posted: Wed Mar 01, 2006 11:06 am
Use the voltage offset in the Wideband Lambda settings. Adjust it either positive or negative until the display and smanager read the same.
Posted: Wed Mar 01, 2006 11:12 am
by Shadow!
Spunkster wrote:Use the voltage offset in the Wideband Lambda settings. Adjust it either positive or negative until the display and smanager read the same.
Ok.
I used offset -0.24
