Reporting Bug!!
Posted: Mon Jan 09, 2006 8:42 pm
by Jordo
When "ON-board Datalogging" is enabled, and set to certain conditions, and you have a laptop pluged in also to datalog.
If you do a pull, the smmanger will freak out.
To fix problem, "disable on-board datalogging"
Posted: Tue Jan 10, 2006 10:35 am
what version are you referring to?
Posted: Tue Jan 10, 2006 3:02 pm
by jdmspecdc5
this would explain why sometimes the s300 bugs out and pretty soon im boosting 360psi @ 60,000rpm haha. thanks for the tip. hopefully it gets rid of this problem.
Posted: Fri Jan 13, 2006 3:52 pm
by Jordo
jdmspecdc5 wrote:this would explain why sometimes the s300 bugs out and pretty soon im boosting 360psi @ 60,000rpm haha. thanks for the tip. hopefully it gets rid of this problem.
Yes, it will fix the problem is you just disable it.
Spunkster wrote:what version are you referring to?
newest version.
Posted: Fri Jan 13, 2006 4:28 pm
I cannot report problems without the exact version number found in Help, About.
Also it is best to have onboard datalogging disabled unless you are gogin to be at the track or the laptop is not accesible for datalogging.
Posted: Mon Jan 16, 2006 10:40 pm
by Jordo
its version 1.1.0.0 according to the about
Posted: Tue Jan 17, 2006 10:10 am
Try checking for updates. Version 1.1.1.0 is the most recent version.
